Sigma 17-70 with 2x converter v telephoto lens - which for quality?
Discussion in 'Photography Forums' started by StevePn, May 2, 2007.
  1. StevePn
    StevePn
    Nov 15, 2004
    167
    Salisbury
    +5
    Can't afford to get a Sigma 17-70 and a good telephoto lens yet.
    Instead would using a 2 or 3 x converter give good results with the Sigma over a cheaper telephoto lens?
    Steve
  2. denno75uk
    denno75uk
    Oct 17, 2006
    1,980
    116
    Leeds..out of Prescot
    +574
    Probably not a good option. The 2X converter would make the lens a 140mm at the long end which is not particularly long, you lose AF, some IQ and you lose two stops on the aperturemaking it very slow.
    Wouldn't you be able to get the 70-300 APO for around the same money as a converter? Especially if you use somewhere like onestopdigital.
  3. RobDickinson
    RobDickinson
    Mar 8, 2001
    4,756
    Christchurch , New Zealand
    +748
    The 2* convertor converts both the focal length and the apature.
    So 2.8 becomes 5.6, thats the wide end, the long end becomes f9.
    Your camera wont AF past F5.6
    Typicaly long lenses will be built diferently too, and as said above theres prob some longer lenses for the same price as extenders.
  4. jonnypb
    jonnypb
    Dec 4, 2005
    4,130
    Cumbria
    +559
    if money is an issue then as said above the sigma 70-300 APO is very good value for money and will produce good results. Think it's around £115 from one stop digital
  5. BananaTiger
    BananaTiger
    Oct 25, 2005
    1,194
    +124
    Also, I'm not 100% sure but I don't think that teleconvertors work with EF-S or equivalent lenses.
