Question Sigma 17-50mm F2.8 nikon, rattling
Discussion in 'Photography Forums' started by JDR82, Jun 25, 2015.
  1. JDR82
    JDR82
    Mar 28, 2012
    1,241
    116
    +946
    Hey another question, I bought a brand new Sigma 17-50mm f2.8 Nikon Fit lens from Wex Photographic last week, just finally got around to having a play with it today and noticed something none of my other lenses do.
    When holding it with the lens facing upwards if I shake it gently there is quite a noticeable rattling noise of things moving about, is this normal, does anyone else own this lens and able to confirm whether theirs is the same or silent?
    Just want to see if I should be returning this or if its fine, took a couple of quick shots AF and OS are both working fine.
  2. twist
    twist
    Nov 19, 2006
    16,363
    +5,012
    Its likely the OS and thats normal.
