Sigma 100-300 f4 Test.
Discussion in 'Photography Forums' started by Chubster, Jan 6, 2012.
  1. Chubster
    Chubster
    Nov 16, 2008
    1,746
    63
    Haslemere
    +149
    Ok, have to admit I havent had much of a chance to actually use this lens and when I have light hasnt been optimal but Im not sure if I have a slightly soft one. (lens that is :) )
    This shot was taken at 300mm f4, what do you think?
    [​IMG]
    Sigma test by ob1chubster, on Flickr
    It looks ok as is, but if I zoom to 100% it looks a lot softer than I would expect
    See here
    This was taken on a tripod using the cameras self timer so it should be as sharp as I can get it (without mirror lockup)
    Opinions really appreciated
  2. godsakes
    godsakes
    Dec 3, 2007
    1,685
    York
    +314
    try micro adjust if you have the option but otherwise I'd say you have a bad copy - I've had a copy of that lens in the past and it was much better
  3. twist
    twist
    Nov 19, 2006
    16,315
    +4,992
    Hmm why is it soft...... F4 @ 1/8 300mm ISO 100 on a cloudy day.
    Set it at F4 ISO 200 set shutter at equiv to focal length on a tripod. Then try again. If it still is the same then it needs microadjust or a Sigma AF adjust.
  4. Chubster
    Chubster
    Nov 16, 2008
    1,746
    63
    Haslemere
    +149
    Hmm...I assumed that if its on a tripod shutter speed shouldnt matter, no :confused:
  5. BubbleDouble
    BubbleDouble
    Jan 13, 2009
    4,227
    2
    Space
    +1,883
  6. twist
    twist
    Nov 19, 2006
    16,315
    +4,992
    Lenses are sometimes soft but its only due to a focus adjustment issue, they dont have rubbish glass. Its not a myth just a misunderstanding of whats up.
  7. eddiewood
    eddiewood
    Dec 11, 2007
    6,722
    +1,145
    How about indoors with external flash, the old row of batteries test.
  8. eddiewood
    eddiewood
    Dec 11, 2007
    6,722
    +1,145
    oh I ordered a Focus Pyramid yesterday to have a crack at AF adjustment on my A77. I looked at the DIY jobs and really couldn't be bothered with them for the sake of 10 dollars plus US postage...
  9. Chubster
    Chubster
    Nov 16, 2008
    1,746
    63
    Haslemere
    +149
    Dont have external, could try it with on board ??
  10. eddiewood
    eddiewood
    Dec 11, 2007
    6,722
    +1,145
    I was just thinking with external you could increase the distance, but if it needs adjustment it'll not matter what the distance is as long as it's not within the minimum focus distance of course. At least it'll be a quick and dirty check.
  11. Chubster
    Chubster
    Nov 16, 2008
    1,746
    63
    Haslemere
    +149
    Have to admit Im a bit confused with the whole battery test thing, I can see how it works with primes but not zooms, you can only adjust for one focal length ?
  12. Chubster
    Chubster
    Nov 16, 2008
    1,746
    63
    Haslemere
    +149
    Twist, do you know how much sigma charge for calibration for out of warranty lenses ?
  13. godsakes
    godsakes
    Dec 3, 2007
    1,685
    York
    +314
  14. eddiewood
    eddiewood
    Dec 11, 2007
    6,722
    +1,145
    I was suggesting a quick test with batteries, not AF adjustment. :smashin:
  15. Chubster
    Chubster
    Nov 16, 2008
    1,746
    63
    Haslemere
    +149
  16. Chubster
    Chubster
    Nov 16, 2008
    1,746
    63
    Haslemere
    +149
    Ah, ok....off to raid the remotes :)
  17. twist
    twist
    Nov 19, 2006
    16,315
    +4,992
  18. Chubster
    Chubster
    Nov 16, 2008
    1,746
    63
    Haslemere
    +149
    OK, done a quick and dirty battery test, not sure if I did it exactly correctly but to my eyes the one at 300mm is very soft. Off to Sigma then ?
    100mm
    [​IMG]
    sigma test-2 by ob1chubster, on Flickr
    300mm
    [​IMG]
    sigma test-3 by ob1chubster, on Flickr
  19. twist
    twist
    Nov 19, 2006
    16,315
    +4,992
    300mm does look soft but is that a crop or entire image? Try stopping down to F5.6 at 300mm. These lenses dont really perform at 300mm at MFD try get a bit further away like the first shot if possible. BTW your batteries arent correctly aligned so test isnt a good judge.
  20. twist
    twist
    Nov 19, 2006
    16,315
    +4,992
  21. twist
    twist
    Nov 19, 2006
    16,315
    +4,992
    Youre stacking the batteries next to each other instead of behind and off slightly so you wont see the DOF change.
  22. twist
    twist
    Nov 19, 2006
    16,315
    +4,992
    Camera sensor inline with the center of the middle battery, each battery should be staggered half a battery apart horizontally and about an inch apart front to back further for smaller aperture lenses.
  23. Chubster
    Chubster
    Nov 16, 2008
    1,746
    63
    Haslemere
    +149
    That was entire image, shot same distance as the 100mm one. Ta....Will do again
  24. eddiewood
    eddiewood
    Dec 11, 2007
    6,722
    +1,145
    ....and did the missus think you'd just gone mad? Mine did when I started taking pictures of batteries....
  25. twist
    twist
    Nov 19, 2006
    16,315
    +4,992
    Wait till you start taking pics of cereal boxes and washing powder boxes :blush:
  26. eddiewood
    eddiewood
    Dec 11, 2007
    6,722
    +1,145
    We're not geeks really...
  27. twist
    twist
    Nov 19, 2006
    16,315
    +4,992
    ..... were just misunderstood.
  28. Chubster
    Chubster
    Nov 16, 2008
    1,746
    63
    Haslemere
    +149
  29. Chubster
    Chubster
    Nov 16, 2008
    1,746
    63
    Haslemere
    +149
    Haha, she gave up on me when I first went out with the spiderpro belt adaptor and camera hanging off it :rolleyes:
  30. Liquid101
    Liquid101
    Jan 30, 2006
    8,029
    Aberystwyth
    +3,083
    There are always going to be compromises with zoom lenses. However, the first image you posted looks more like camera shake than anything.
    Does it have a tripod collar? mounting it on a tripod using the camera mount is going to amplify any tiny movement.
