TangoMango
I have a little toddler that decided to press all the button on the oven display the other day and now the Siemens oven won't turn on if you set it above 80°C. On the display it shows 80°C with and arrow going up and if you turn on the oven at more than 80°C it'll beep twice and turn the light off and on again and then repeat indefinately. I called the Siemens support and I guess it wasn't in their manual as they had no clue. Does anyone know how to fix this?
