redsox_mark
While I generally try to avoid it, I have a need to use my Plasma (Panny PW6) in 4:3 mode.
Im confused about the screensaver modes for the side panels. I have options to have the side panels lit (grey), either low, medium, or high. (Default is off, so the side panels are black).
The manual tells me:
1. Do not display a picture in 4:3 mode for an extended period, as this can cause an after-image to remain on the side panels either side of the display field. To prevent the appearance of such an after-image, illuminate the side panels.
Then later it says:
2. Setting the side panel to High mode for an extended period may result in occurrence of after-images.
So Im confused as to what is the best (safest) setting. It sounds like I should have the panels lit, but lighting them high sounds like a problem too. So Ive currently got it set to low.
Can anyone help me be less confused?
Mark
Then later it says:
Mark
