side fix coda 8,s
Discussion in 'Home Cinema Speakers' started by chris thomas, Jul 5, 2002.
  1. chris thomas
    chris thomas
    could someone please tell me if its ok to mount a pair of kef coda 8,s on there side in a 6.1 set up has they are being used has the side surrounds, thanks in advance. ;)
  2. Jase
    Jase
    Mar 16, 2001
    10,740
    United Kingdom
    +2,525
    Hi Chris
    Give it a go, you can´t do any damage to them. Just they might not sound as good on their side as mounted vertically.
    Cheers:)
