Side bars on 4:3 pics broadcast as 16:9
Discussion in 'Plasma TVs' started by iandmcneill, Jul 27, 2005.
  1. iandmcneill
    iandmcneill
    Dec 11, 2002
    58
    According to the manual for my PWD7, side bars are one of the mose likely causes of screen burn, and that protection should be turned on. I can get this to work fine for 4:3 signals, but sometimes, it seems as though pictures from channels are sent 16:9, but are only a 4:3 picture and the rest of the frame is filled with a black bar. In turn, the PWD7 does not see this as a 4:3 signal and does not use the grey bars. For example, currently the Bratislava Vs Celtic game on BBC1 Scotland.
    Does anyone have any recommendations on solving this. At the moment I just set my Topfield to 4:3 and that fills the screen - is that the only way. I connect using component signal.
    Ta,
    Ian
  2. stevelup
    stevelup
    Aug 13, 2002
    6,142
    Swindon
    +855
    I wouldn't worry about it. The later generation Panasonic panels are all but completely immune to screen burn.
    I don't recall a single recorded incident on these forums where anyone has suffered.
    Steve
  3. iandmcneill
    iandmcneill
    Dec 11, 2002
    58
    Cheers,
    Will relax and just watch now ;)
    Ian
