Sick Pioneer
Discussion in 'AV Receivers & Amplifiers' started by KAO, Mar 3, 2002.
Tags:
  1. KAO
    KAO
    I have a Pioneer VSA-E07. Yesterday I came home from work, switched it on via the remote (I leave it in standby mode) and there was a sharp, but not overly loud, cracking sound. Now there is still sound from all channels, but all channels have a very distracting crackling noise in the background, sometimes louder than the signal itself.
    Is this the amp, or have I blown all my speakers (I don't have access to another amp or speakers right now so I can't eliminate either).
    Any suggestions? Of course, it's out of warranty now :(
  2. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    Unlikely that all speakers are blown though I won't exclude that possibility totally.
    Are you handy with a screwdriver and dare to open the cover (disconnect AC first!)?
    Check if there is a loose screw holding down the PCB, had a stereo amp which did a similar thing due to a loose screw which connected the PCB to the ground.
    After a few month the screw loosen itself and the problem cam back, tightened it and put some glue on it - solved for good.
    If you don't think you want to do this narrow down the problem and get a repair shop to check it out.
  3. KAO
    KAO
    Reiner, thanks for the suggestion. I think I'll give that a go...
