sick panasonic video recorder
Discussion in 'Digital TV & Video Players & Recorders' started by davee b, Sep 26, 2001.
Tags:
  1. davee b
    davee b
    Jul 19, 2001
    299
    leeds
    +14
    i've started getting an intermittent fault with my panasonic nvhd620 3 and a bit year old video.<br />i get total loss of sound and a central noise bar which splits into two, one moves up screen and one moves down. this repeats about every 2 seconds. this can happen with prerecorded or home recorded tapes although it tends to happen more with older prerecorded ones than with new ones. does anyone know what the possible problem/cure is or is it goodnight vienna. <br /> tia.
    <img src="eek.gif" border="0"> [/LIST]
  2. Guest
    Sounds like one of a multitude of faults that a vcr can develop in its lifetime. One for the repair man I suppose.
  3. Paul O
    Paul O
    Nov 2, 2000
    481
    UK
    +21
    Could be dirty heads. Have you tried a head cleaner?
    Or it may be that the auto-tracking is not working properly. Try manually tracking it.
    Failing that - yep it needs to go back I think! :-(
    Cheers,
    Paul.
  4. General Skanky
    General Skanky
    Jul 28, 2000
    4,252
    71
    Colchester
    +44
    Common faults on that deck were....
    worn pressure roller - causes tape to ride up and down audio/control head, hence your problems.
    Worn video head drum upper or lower - same probs.
    As said, simply dirty heads.
    Also they had a tendency to break the loading motor coupling that connects to the motor drive shaft. It splits and causes the tape to load incorrectly and so same faults.
    Approx parts prices...roller £15+, coupling 15p or head drums £50+ each. All plus labour of course, ie £35+ let's say.
    Dirty heads you can plonk a tape cleaner though to try or do it yourself.
    Search vcr repair on www.dogpile.com and it'll throw up loads of info.
    Good luck.
  5. davee b
    davee b
    Jul 19, 2001
    299
    leeds
    +14
    Having considered and discounted the dirty heads/tracking options, the worn pressure roller explanation would seem to fit the bill. anyway people thx for all your advice. :eek:
  6. General Skanky
    General Skanky
    Jul 28, 2000
    4,252
    71
    Colchester
    +44
    I'll have look and see, but I'm 99% positive I have a spare roller floating about you can have free if you wish. Very simple to fit too.
    I'll have a look throuhg my old spares and let you know.
  7. davee b
    davee b
    Jul 19, 2001
    299
    leeds
    +14
    Thanks. that would be great if you do have one. :cool:
  8. General Skanky
    General Skanky
    Jul 28, 2000
    4,252
    71
    Colchester
    +44
    Yes I do.
    If you e-mail your address to me at [email protected] I'll plonk it in the post with a few notes.
    You do realise this'll make Taz jealous. I didn't have one for his model of vcr, as it's so old. :)
  9. General Skanky
    General Skanky
    Jul 28, 2000
    4,252
    71
    Colchester
    +44
    The roller is/was in the post. You should have it by now.
    If you need any info just call.:)
