Shuttle Newbie
Discussion in 'Desktop & Laptop Computers Forum' started by Loafer316, Jun 5, 2003.
  1. Loafer316
    Loafer316
    Apr 8, 2003
    330
    Hi. Ive just order a Black SN41G2 Shuttle for my little sister..and i know it sounds dumb but...does it mean i only have to buy an OEM CPU because the shuttle come with a heatsink?:zonked:
    Also i've heard that these little shuttles can be noisy. I've heard the 40mm ADDA fan be mentioned for the PSU..i found it for £10..unfortunatly delivery was £8!...anyone know a cheaper alternative!! plus am i coreect in thinking i could replace the rear fan with a 80mm of my choice? like a papst or panaflo?
    Thanks for the help ppl.:hiya:
  2. HMHB
    HMHB
    Nov 11, 2001
    25,598
    Nottinghamshire
    +3,944
    It would be cheaper to buy an oem version of the chip - but you could buy a retail version and keep the fan for use if you decide to take the chip out of the shuttle.
    There's a good small form factor area on Kustompcs forum:-
    Kustom PC Forum
  3. gab2001uk
    gab2001uk
    Dec 3, 2002
    236
    +5
    You can use the small radial CPU coolers on Athlon chips from http://www.quietpc.com/uk/cpucool2.php and replace or remove the fan at the back completely. It is not exactly silent, but quite acceptable
