Shuttle case for HCPC
Discussion in 'Desktop & Laptop Computers Forum' started by chalkdust, Jul 22, 2003.
  1. chalkdust
    chalkdust
    Jul 8, 2003
    717
    +20
  2. biggygiant
    biggygiant
    Hi Chalkdust,
    I have a Shuttle SB51G running:
    P4 2.55 GHz processor
    512 MB Corsair RAM
    80 GB WD HDD (IDE)
    HP cd-writer 9500
    ATI Radeon 9700 Pro
    M-Audio Revolution 7.1
    and love the case for its size, looks and convenience.
    BUT
    it is quite noisy. I have worked hard to voltmod the Radeon fan, replace the stock case fan and even stuck in a little Akasa paxmate sounddampening material, and it is now fine for a desktop environment - but it would drive me nuts in a HTPC environment... I think it comes down to what components you want to put in it though...
    I am also in the process of building a HTPC and am looking at the LMP, DIGN/ACCENT cases as the best option. There are alot more choices of silent or near-silent components for fullsize ATX boxes (even a fanless PSU now!).
    Just my .02 worth...
    cheers,
    Martin
  3. chalkdust
    chalkdust
    Jul 8, 2003
    717
    +20
    Thanks biggygiant,
    I think I may go the route with a bigger case as you say you can get a lot more into it. The LMP ones do look a good bet.
