Shutting down PS3 in Remote Play mode
pavr27
Not sure whether this should be in the PS3 or PSP forum.
I have a PSP and use Remote Play to use the PSP to select and play my music outputting through the PS3 (Great new function!!)
However, when I come to shut down the PS3 using the PSP the PS3 very often does not shut down correctly (ie, i get the three beebs instead of the two....and it does not shut down with remote play enabled (ie the little green light showing in standby)
Anybody else have this problem?
evilgenius
What does that mean? Your ps3 has speakers on it, sorry i dont follow.
beasty54
Not sure why you dont understand that but he means the sound is being output by the PS3 and not the PSP during remote play, so in other words its coming through his TVs speakers or other audio setup.
To the OP... I have used remote play for a while and the PS3 always seem to shutdown ok so all i can suggest is that you reset the PS3 back to its original state and set it up again.
Podcast: Panasonic HX800 TV + Sony HT-G700 Soundbar reviews, movie and TV show news and reviews
