Shredder?
Discussion in 'General Chat' started by Rock Da Bass, Jan 18, 2008.
  1. Rock Da Bass
    Rock Da Bass
    Jan 27, 2002
    5,815
    EU
    +847
    I've decided to buy a cross cut shredder for disposing of household documents etc.
    I'm not sure how to choose a good one though. Any recommendations? It would just be for household use, preferably with auto-start if it detected something being put in.
    Thanks in advance for any replies.
    RDB :)
  2. GW43
    GW43
    Feb 27, 2005
    1,661
    63
    Out of my mind on dope and speed
    +168
    I got one from Tesco a couple of years ago - £15 if I recall. Works fine, gets a bit warm with prolonged use, but it's been ok.
  3. Geege
    Geege
    Jun 27, 2006
    2,974
    +430
    What budget do you have? There are a few features you need to consider. I personally wouldn't go for less than security level 3 and would recommend a cross cut one instead of a striped cutter. Auto feed/cut off seems to be the norm and you can also get ones that cut credit cards/CD/floppy disks too.
    Try and go for around 8-10 sheets of paper feed at once minimum.
    I've just brought a shredder for use in the home. Swordfish 2000XCD costs about £130 and it is much much better than the crappy £20 ones.
  4. Rock Da Bass
    Rock Da Bass
    Jan 27, 2002
    5,815
    EU
    +847
    I've noticed some are Din Level 3. I take it that means security level 3 and probably refers to the size of shredded bits?
    Budget would be up to about £80 for a fairly good one.
  5. Drd
    Drd
    Jan 22, 2005
    1,904
    Approaching the doghouse at great speed
    +301
    Yes,it may be,but my £20 from Argos has survived 3 years and is a perfectly acceptable cross cut dosmetic shredder.I've got a far superior shredder at work for sensitive/confidential documents,but this is not what most of us need for our bank statements etc.
    There was an advert in the Telegraph a short while back for a shredder that exceeded all US/UK specification for any documents.I can't find it online,but IIRC it reduced a sheet of A4 to over 60,000 fragments:eek:Why not just incinerate it then powder it?
  6. danmc_82
    danmc_82
    Jan 19, 2007
    5,630
    Skynet Border
    +1,212
  7. Rock Da Bass
    Rock Da Bass
    Jan 27, 2002
    5,815
    EU
    +847
    Thanks for the offer. I live near 2 Sainsburys and will have a look this weekend. :thumbsup:
  8. Miyazaki
    Miyazaki
    Sep 10, 2003
    14,393
    +850
    Buy a couple of gerbils. Should cost you around £5.
  9. jolly
    jolly
    Dec 5, 2003
    3,478
    83
    North Yorkshire
    +153
    I have 2 Hamster's, would they do
    Steve
  10. Member 328449
    Member 328449
    Aug 31, 2007
    3,431
    Kent
    +342
    [​IMG]
  11. Drd
    Drd
    Jan 22, 2005
    1,904
    +301
    That made me laugh probably more than anything else will this weekend.10/10:rotfl::rotfl::rotfl:
  12. stevefish69
    stevefish69
    Jun 25, 2004
    4,278
    +487
    I use a cheapo cross cut shredder that i picked up for about £15 from Rymans
    The contents are then used to start the chiminea in the summer months :thumbsup:
  13. danmc_82
    danmc_82
    Jan 19, 2007
    5,630
    Skynet Border
    +1,212
    :D
  14. Drunkeh
    Drunkeh
    Nov 16, 2006
    597
    +39
