Showshifter / Sweetspot questions
Discussion in 'Desktop & Laptop Computers Forum' started by 911uk, Sep 16, 2004.
  1. 911uk
    911uk
    Looking to build my new system using the SweetSpot card with three sources: Sky digibox (RGB), VHS video recorder (SVHS) and a FreeView box (SVHS). Will use PC's internal DVD for playing/recording, though tempted by the Xcard.
    1) Will I be able to connect 2 VHS sources and the RGB source at the same time?
    2) Can Showshifter switch between these and allow recording of one and viewing of another?
    3) Will the quality from the Sky box be as good as RGB via JS Plasma VGA box to Plasma when feed through the Sweetspot?
    Thanks in advance guys!
  2. David PluggedIn
    David PluggedIn
    Oct 14, 2003
    544
    +10
    Hi Phil
    Why not use an RGB Scart switch, taking the Sky box and the Freeview box in to SweetSpot RGB. That will then leave you with SVideo2 input free for your SVHS VCR.
    The quality will be better using SweetSpot, as the JS VGA boxes (excellent though they are) are not performing any video scaling/deinterlacing, which is what you are getting on a SweetSpot enabled HTPC.
    btw there is a trial version of ShowShifter on the SweetSpot CD so you can get a real good view of its capabilities.
    cheers
  3. 911uk
    911uk
    Thanks David. However, I've just realised that I could simply plug the freeview box into the Video - Doh!
    I look foward to seeing the results of the SweetSpot card as I thought that the JS box was already giving me the best possible picture.
  4. David PluggedIn
    David PluggedIn
    Oct 14, 2003
    544
    +10
    Oh yes, that would also work :)
    I would still be tempted though to use the RGB output from the Freeview box as that will be better than Svideo..
    good luck
  5. surrey lad
    surrey lad
    Dec 14, 2002
    665
    Kingswood, Surrey
    +21
    911uk,
    David is right, forget s-video if rgb is available. Try looping the rgb scart feed from the sky box to the second scart connecter on the back of the freeview box (if it has one) or the other way round, you may find that one of them has rgb pass-through saving yourself the cost and the need for 'another box'.
    surrey lad ;)
