Showcentre Basic's Please
EAZYROG
Hi all,
Just got myself a showcentre and a little confused how i should wire the system up for HDTV.
Currenlty i've hooked it up using a standard Scart to Scart Lead, my plasma has a DVI input ready for HDTV but i cant figure out what the showcentre use's.
Hope someone can help.
Roger
Tarbat
The HiDef output on a Showcenter 200 is component. Use the component sockets, and set video output to HDTV 720p (or 1080i).
Stephen Neal
EAZYROG said:
thanks for that,
What your saying is i need a compnent to DVI adaptor, what about sound too ?
Your HD display should have an analogue component HD input as well as DVI if it is HD Ready - unless it is one of the few that have combined analogue and digital DVI-I sockets - and accept component as well as RGB via the analogue bit of the DVI-I socket.
If your display has a digital only DVI-D input then it will be difficult to convert HD component to DVI-D (as this will require an A/D conversion process etc.)
Certainly a component HD connection will improve on an SD RGB SCART if you are playing HD media.
xxalxx
what model plasma do you have ?
xxalxx
we know that one m8, but what model telly do you have :)
Al
Chris Nicholl
That's handy then! :suicide:
If you look at the screen on Philips website it makes no mention of component inputs, have a look at page 6 of their on-line manual here it does.
It would seem to say that the VGA socket will take a component signal so the included (according to the website) VGA to YPbPr-Cinch cable should do the trick.
The specifications here on the other hand doesn't mention a VGA socket...
Tarbat
Yes, all I did was check the specification on the Philips website. I guess EAZYROG just needs to read the manual for the plasma to see whether it can accept a component input.
