Showcenter hookup
Discussion in 'TVs' started by ColdKilla, Aug 8, 2005.
  1. ColdKilla
    ColdKilla
    Jun 21, 2005
    726
    +21
    I have a PV500 and was looking at streaming some HD wirelessly from my pc I am running 54g.
    I read the showcenter 200 can do a reasonable job of this but I wondered how I can hook it up to my PV500.
    You see atm I have component leads from DVD to Plasma and dont want to lose that connection or even downgrade it in any way - Can I hook the showcenter up via another connection and retain HD or will I have to double up the component input if so how and will I lose quality?
    CK
  2. YellowCows
    YellowCows
    Dec 15, 2002
    141
    Sadly, component is the only way to get HD out of the showcenter.
    You have an AV amp with component switching (it's even compatible with HDTV signals), why not run both the DVD player and the showcenter through that to your display? You'll be able to get OSD that way too.
    HTH :)
    Moory
