Show Me Your Projector Setup - Picture Thread
Discussion in 'Projectors, Screens & Video Processors' started by Monkey Alan, Jul 11, 2005.
  1. Monkey Alan
    Monkey Alan
    Jan 19, 2005
    628
    +39
    I'm thinking of getting a projector and was wondering how you guys have it setup. Have you got really long scart/component cables running from front of the room to the projector at the back/ceiling or do you have all your equipment next to the projector.
  2. nero0410
    nero0410
    Jan 5, 2004
    11,593
    southwest
    +4,346
    I have all my equiptment running down one wall have have a 3 metre lead feeding the projector.
    I set it up on a shelf unit and put it away again when finished
    tris
  3. scumball
    scumball
    Jan 12, 2004
    6,209
    Harrow - London
    +410
    I've got a through lounge and have a shelf unit across the middle as a room divider. On this is the PJ and all the source equipment and surround speakers. The screen pulls down in front of my bay window/curtains and as such forces a dark room for viewing. It works for my setup really well. the only downside so far is the back of the unit is a mass of cable even when using those cable management tube thingies...
  4. cyberheater
    cyberheater
    Apr 3, 2003
    3,186
    Scotland
    +170
    I've got my projector on a back wall shelve with my DVD player and power.
    The only lead i've got from there is my optical 5.1 to my AV amp.
  5. PJTX100
    PJTX100
    Dec 21, 2004
    8,129
    +562
    Ceiling, 15m cables - DVI / component / s-vid / composite - just need VGA and I'd have a full set!...PJ :)
  6. Monkey Alan
    Monkey Alan
    Jan 19, 2005
    628
    +39
    Thanks for the replys an keep um comin :thumbsup: , I still trying to decide which is the best setup to use. PJTX100 don't those long cables cause you problems, lose of quality ect?
  7. Crivens
    Crivens
    HS50 attached to ceiling (Vogel mount), with S-Video and power cable going along ceiling and down wall on (I think) about 15 metre cables connecting to my Technics unit (old but good enough with built in 5 disc DVD - good for LOTR extended versions, although not for the whole lot : is 6 *discs* all in :( ). Both cables held in one of those plastic storage thingies that stick to the wall. Looks good. Hi-fi is then connected to 5 speakers, with about (I think) 20 metres of cabling per speaker. Stuffed them tight against the wall, behind most furniture so is hardly noticeable. Should really connect these cables properly to the wall, but can't be arsed.
  8. PJTX100
    PJTX100
    Dec 21, 2004
    8,129
    +562
    Nope, the pic is so sharp you can cut paper with it - especially on component. Very clean, no funnies. DVI length was a worry but the Lindy cable works fine for me. Composite looks pants but that's just for aging VHS. S-vid looked surprisingly good, but don't really use that now...PJ :)
  9. Monkey Alan
    Monkey Alan
    Jan 19, 2005
    628
    +39
    ^Thats good to hear :smashin: . What I think I'm gonna do is get a 10m component cable to connect my dvd and a 10m s-video to connect my grundig sky box and xbox via some sort of switcher (not sure what though).
    Where did you get your cables from, I found this site but that seems too cheap to be true :confused: .
    http://www.tvcables.co.uk/cgi-bin/tvcables/CP003.html
  10. Crivens
    Crivens
    As it turns out I bought my S-Video cable from the place you mention above. Is actually this : IXOS XHV403-500 5m S-Video (just found invoice). Just remembered that it is actually 5 metres, not 15 (moved DVD unit nearer to projector). Quality is top notch. I browsed a bit on IXOS cables, and found they had really good reviews. If I remember rightly TVCables.co.uk delivered it within like 2 or 3 days. Good stuff.
  11. sbowler
    sbowler
    Mar 24, 2005
    3,795
    Leeds
    +487
  12. Monkey Alan
    Monkey Alan
    Jan 19, 2005
    628
    +39
    Finally some pictures :thumbsup: . I'm thinking of getting the AE700E but my wallets telling me to get a cheaper epson TW10H I've seen. But then I keep thinking about xbox 360 an HD an sky HD an want the AE700 but I've heard there is no difference between the 2 for dvd playback and pannys suffer from low brightness an banding? I don't know what to do,am I going to see a big difference in dvd playback between the AE700E an TW10H?
  13. Crivens
    Crivens
    Well if you want HD then you need the Panny. The other one doesn't have the resolution.
  14. mikeaitch
    mikeaitch
    Apr 21, 2001
    1,583
    Stoke
    +55
  15. inzaman
    inzaman
    Dec 16, 2002
    7,875
    Derby
    +929
    Mine too is ceiling mounted with two 7.5 metre DVI leads (one spare for hdmi) and one 7.5 metre component lead. I have made a DIY ceiling mount to ount it as well, see picture of it here
  16. MacReady
    MacReady
    Jun 25, 2003
    2,219
    Barnsley, South Yorkshire
    +102
    My pj is ceiling mounted with 3 15m cables for componant running into the celing and then under the bedroom floor. They come down some trunking which was plastered into the far end of the living room wall and run in trunking behind the skirting board to the amp at the front of the room.
    Link to pics in my signature below :)
