Should Sky+ do this....?
Discussion in 'Sky Digital TV Forum' started by Northerner, Dec 12, 2003.
  1. Northerner
    Northerner
    Aug 12, 2003
    112
    19
    The land where The Macallan is distilled
    Bit of a greenhorn with this - just had it installed yesterday and cooling fan seems to run all the time. Still running this morning.
    Also set it to record "Wyatt Earp" Channel 5, last night, but recording is only 58 mins - should have been 3hrs 30 mins.
  2. NicolasB
    NicolasB
    Oct 3, 2002
    6,459
    Emily's Shop
    +898
    The latter is because the film was split into two parts, before and after the news on Channel 5. Sky+ (not unreasonably) regards the two parts as two different programs, do you have to set it to record both.
  3. Fernsehman
    Fernsehman
    The former because the SKY+ box is running too hot. It should be installed on an open shelf away from sources of heat and in a room of ambient temperature as low as possible. The fan comes on automatically when the temperature inside the box gets too high.
    Of course, it could be a faulty temperature sensor or maybe Pace have had so many failures that they've changed the design to make the fan run all the time. (Are you sure it's the fan noise and not the Hard Drive?)
    Fman
  4. Brogan
    Brogan
    Oct 9, 2003
    7,582
    Cary, North Carolina
    +482
    If you reboot the box by removing the power it should stop the fan running continuously.
    For some reason, the cooling cycle doesn't seem to work when the box is first installed.
  5. Northerner
    Northerner
    Aug 12, 2003
    112
    19
    Ooops :eek: :eek:
  6. kill3r
    kill3r
    Dec 12, 2003
    39
    I had to unplug then reboot my new Sky+ box to get the fan to stop. Although since I did that it's not ever come back on.
  7. Northerner
    Northerner
    Aug 12, 2003
    112
    19
    Yep - that's solved the problem. Everything seems to fine now.
    Thanks for your help
  8. Stereo Steve
    Stereo Steve
    Jul 11, 2003
    1,939
    38
    UK
    +7
    Happened to me too on first install. Very strange.
