Should output on sky+ etc be gold just like all the scarts we buy?
Discussion in 'Cables & Switches' started by Widescreenx, May 26, 2005.
  1. Widescreenx
    Widescreenx
    Mar 29, 2005
    45
    Surely the outputs on amp should be copper plated to get the ultimate reception as well as the scarts we feed into them or is there something I'm missing? :rotfl:
  2. Gregory
    Gregory
    Mar 27, 2005
    312
    Midlands
    +9
    Yes, they should - and on many amps/DVD's etc connections, especially RCA, are (gold plated, that is, not copper plated). Scart often isn't simply because it's (a) expensive, and (b) people after a really decent quality video signal will usually go component (hence the gold-plated RCA outouts and inpiuts on DVD's/AV amps etc). However, for most purposes it shouldn't make much of a difference (only really matters if the connectors are tarnished).
    Greg
  3. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,545
    Near London.
    +208
    A good point indeed and one that I've always wondered about, if there's going to be a source of signal degradation at a connection point then a transition between metals will be very near the top of the cause list. But who would think to use nickel/tin plated plugs on such sockets and only gold-plated plugs on plated sockets?
    Copper would be a very poor choice for plating sockets as it oxidises really quite quickly, silver would technically be the preferred option over gold. Having said all that, I really don't think that the difference would be perceptible. :)
  4. Gregory
    Gregory
    Mar 27, 2005
    312
    Midlands
    +9
    As I understand it the reason to use gold is to avoid non-conducting tarnishes/oxide layers. Gold is an inert metal, so it doesn't oxidise - most other do oxidise (including silver which is, if I recall, a passive metal - meaning that it does oxidise, but that the oxide layer prevents further oxidation, so making the oxide layer only a few atoms thick).
    I do not think that the difference in metals makes a huge difference - the voltage from a differing metal junction is absolutely tiny, even by comparison with an interconnect or video level signal. And, if you think about it, there are a huge number of differing metal junctions in the chain from source to use (including between the base metal and the gold plating of gold-plated plugs).
    What can make a difference is any tarnishing or surface contaminants on the plugs - gold helps avoid the tarnishing; a tight connection helps with mechanical wiping to clean the area being contacted.
    Greg
