Should new draper screen be flat?
Discussion in 'Projectors, Screens & Video Processors' started by Such, Sep 24, 2004.
  1. Such
    Such
    Dec 27, 2003
    2,244
    63
    Greenhithe
    +118
    I've just finished putting up a draper luma high contrast 92" screen and have noticed quite a few ripples or bulges. is this normal for a new screen or should they be perfectly flat?
    I'll see if I can insert a picture, as I've sent some to the retailer where I bought it.
    OK, I can't insert picture, some help needed!
  2. sirp
    sirp
    Jan 20, 2002
    887
    28
    Derby
    +53
    it should be flat...however, there are so many crap screens circulating (im on number 4) that it beggers belief that something isnt done in production!
    do not stand for any ripples etc, send it back, get replacement
  3. Such
    Such
    Dec 27, 2003
    2,244
    63
    Greenhithe
    +118
    Picture attached, I hope:
    This pic may not be too clear, but you can see the ripples from this side view
    :thumbsdow
  4. sirp
    sirp
    Jan 20, 2002
    887
    28
    Derby
    +53
    yes m8, thats horrendous, my second OWL screen was actually that bad...it should be FLAT!
  5. Such
    Such
    Dec 27, 2003
    2,244
    63
    Greenhithe
    +118
    Thought as much.
    I'll be speaking to retailer today. They were very helpful when I chose the screen, i'll see how they are now.
  6. Such
    Such
    Dec 27, 2003
    2,244
    63
    Greenhithe
    +118
    OK, so I've had a reply from the retailer, discount electrical uk, and have been informed that this is 'common' with new screens and the bagginess will 'disappear' after a few uses.
    Are they yanking my chain?!, and if not, how long should I wait for the screen to get flat?
  7. sirp
    sirp
    Jan 20, 2002
    887
    28
    Derby
    +53
    its common with poor screens alright...ive had 4 screens, ones that developed ripples got worse, ones that started with ripples never went. if you look closely, im betting that on the bar at the bottom you will see slight pinch marks where the weighted bar has not been put on very well
  8. Otto
    Otto
    Jun 19, 2003
    322
    28
    +61
    Sometimes it indeed helps for minor ripples to leave the screen completely rolled out. However, if the ripples don't dissappear within about 48 hours, it won't get any better and you need to get it exchanged.
    Best regards,
    Otto
  9. sirp
    sirp
    Jan 20, 2002
    887
    28
    Derby
    +53
    check out the attached picture, they arent minor ripples...they are surfable waves :D
  10. Otto
    Otto
    Jun 19, 2003
    322
    28
    +61
    Only one solution left: replacement....
  11. Such
    Such
    Dec 27, 2003
    2,244
    63
    Greenhithe
    +118
    Thanks for all your feedback. It just confirmed what I thought. I have left the screen down for most of the weekend and it hasn't made much difference.
    I was hoping it would, as it was not easy putting it up with the help of my son 10yrs old and I really didn't want to go through that again!
    The retailer has agreed to swap it, once he looks at the photo.
