Should my volume show -db or +db
Discussion in 'AV Receivers & Amplifiers' started by welshy, Jan 2, 2007.
  1. welshy
    welshy
    May 7, 2004
    854
    4
    46
    Bangor, North Wales
    +118
    This has never caused me any problems but has baffled me for ages.
    My Pioneer Ax5i receiver is usually set between -15 and -20 on the volume control and this is very loud. Any higher than -15 is just too loud. But my hifi amp is usually set to +40 or above. So is my AV volume set correctly, or should that also be in the +db range. Why is one -ve and the other +ve?
  2. Andy98765
    Andy98765
    Feb 15, 2006
    10,472
    2
    +1,365
    0dB = full volumn, so anything less is measured as -xdB
  3. Basil Plumley
    Basil Plumley
    Aug 10, 2000
    8,263
    Enjoying my system - for once!
    +723
    Not quite right actually - 0db = THX ref level on the AX5 (and any THX receiver for that matter). Your volume showing -15 or -20db is actually that figure below THX ref level (which is all channels at 75db from the listening position). If there is a + in the figure, then it's obviously that figure above reference level.
