Should it be left on?
Discussion in 'Subwoofers' started by Vodder, Sep 23, 2004.
  1. Vodder
    Vodder
    Jan 11, 2004
    443
    16
    London, UK
    Do you leave your sub on all the time, except when going away for long periods? Just been reading Whathifi.com and they say you should leave your amp on or standby so it is "always ready to go", is this the same for subs?
  2. recruit
    recruit
    I have always left my subs on or atleast not turned off at the mains and never had any problems, when obviously going away for long periods then yes i will turn the power off.
    John :)
  3. LFCRules
    LFCRules
    Sep 3, 2004
    2,670
    +188
    I can't give you a definative answer, but as per the reply from John, I leave my B&W ASW1000 on permanently. It has been on for the last 20 months since I moved into my flat! And it still manages to shake the room!!
  4. H4r7y
    H4r7y
    Jun 17, 2003
    1,701
    39
    Nottingham
    ive got a swtich on mine, that apparently turns it onto stand by mode after so long, but when it comes on or off theres a hell of a crakling coming through it. is that normal?
    up to now ive always turned it off as i thought it might damage it leaving it on.
  5. Kazman
    Kazman
    Jan 14, 2004
    5,252
    Luton, Bedfordshire
    +136
    You might actually be causing more damage by turning it on and off from the mains frequently. I leave mine on standby, never had a problem with previous subs this way, and I doubt it will cause a problem with the SVS either.
  6. Moviebuff
    Moviebuff
    Aug 10, 2004
    1,997
    Southampton
    +230
    I've left my REL Stadium switched on since 1994 :eek: & apart from moving house,or the odd power cut (must remember to put 50p in the meter),it has never been turned off.It's still going strong,apart from the green illuminated switch not illuminating anymore.
  7. Vodder
    Vodder
    Jan 11, 2004
    443
    16
    London, UK
    Right you's are then - got back home an hour ago and switched the little baby on.... :cool:
  8. Madskilzz
    Madskilzz
    Mar 16, 2002
    252
    Harrow
    +14
    Always leave my sub on, TV I switch off completely, DVD, Amp and Sky I leave on standby. If i'm away for the weekend it's a total shutdown at the mains.
  9. Nimby
    Nimby
    Jan 27, 2004
    9,198
    The Danish Bacon Factory
    +669
    No wonder they need ever more nuclear power. :devil:
    My system sounds better left on. Except for my CD player which sounds brittle with time.
    But after this summer of continuous lightning warnings I now switch everything off and unplug it when I'm not at home. The best sounding system is the one that still works. :D
    Nimby
  10. Mr Cat
    Mr Cat
    Jul 23, 2003
    2,190
    Weardale
    +57
    I always leave my sub on...
  11. Moviebuff
    Moviebuff
    Aug 10, 2004
    1,997
    Southampton
    +230
    I will add that even though I leave most of my gear in standby,all of it is surge protected,against the dreaded mains spikes.
  12. Mr Cat
    Mr Cat
    Jul 23, 2003
    2,190
    Weardale
    +57
    yes, same here.... :thumbsup:
