silly question really!
I might not be a solicitor, but i'll try and word my way around the inevitable answer, to the correct one!
First add a couple of problems. My room is not exactly ideal, I cannot ceiling mount, unless i can place the projector about 4 fot lens to screen! I feel my only location would be within a large wooden coffee table affair, but even then i cant stretch much beyond the 6 foot mark! To fit it into the table, i would need something less than 75x75x30cm. Again perhaps compounding issues, this would mean that the lenses would find themselves a couple of feet lower than the bottom of the screen, which would be 7 foot wide.
So.......with those stipulations, is it still possible? Bearing in mind that i couldnt spend more on a crt than i would get for my sanyo.
Can I have an, impartial, opinion concerning the performances of a cheap crt and my lcd, given that i am an amateur for setting it up!
Thanks!
ad
