Should I use prog scan with an ALIS plasma ?
Discussion in 'Projectors, Screens & Video Processors' started by dUnKle, Aug 15, 2004.
  1. dUnKle
    dUnKle
    Jan 1, 2001
    15,479
    +2,382
    Was happy that my Sony NS930 player outputting prog scan to my 5200 set was a good combination
    However whilst in local store a guy was saying that I should not be using a prog scan player with an Alis set
    Is this correct
    If so what would be the best DVD player to use with my set
  2. cybersoga
    cybersoga
    Apr 7, 2002
    1,630
    48
    UK
    +25
    no he's not correct, your doing the right thing by feeding it a progressive signal, as the dvd player will have a film mode deinterlacer and the display probably won't. if you were to feed it an interlaced signal, it would be deinterlaced by the display's electronics (probably using simple bob mode), upscaled to the native resolution of the display and then reinterlaced at high resolution.
  3. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    It depends on DVD player, I have more experience withFujitsu Alis panels which have very good video processing. feeding them an interlaced signal works very well. Alis is strictly interlaced, but alternatitive lighting of surfaces. Have aplay switching between the 2 and see what looks better.
  4. andrewmellor
    andrewmellor
    Dec 17, 2002
    1,537
    38
    Nottinghamshire
    +23
    Just a quick comment, I have a Pioneer737 that I connected and played back a R1 disc in progressive (dinosaur) and to be honest I couldn't tell any difference between it or playback via SonyS7700 (non prog) through my Fujitsu ALiS panel which ties up with hornydragon's post.
    To be fair I think it would be a task to improve upon the image when fed a good source as I'm very happy with the display...
    As posted try out the options and you make the decision based on the results you see, at the end of the day it's you who's going to be watching it...sometimes there are too many 'experts' out there methinks;)
    Andrew
  5. laser
    laser
    Aug 1, 2004
    988
    Hartlepool
    +46
    Same here. My Pioneer DV-668AV shows no difference in quality on my Hitachi ALIS panel when progressive is either switched on or off.
  6. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    Alis panels dont get the advantages of normal panels, ie a better deinterlacer in the player than panel, as the screen still has a lot of processing to do!
  7. cybersoga
    cybersoga
    Apr 7, 2002
    1,630
    48
    UK
    +25
    It makes a considerable difference when the screen is a Sony (Alis), I suppose that means that the video processing eletronics in a Sony is different.
  8. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    some screens do better at processing Prog to Alis than interlaced to alis. and vice versa. the complex bit is getting video 1024x576 and 853x480 to fit into 1024x1024 then apply Alis! Its a very complex system!
