Should I use BFA or SPADES on 125Ms?
Discussion in 'TAG McLaren Audio Owners' Forum' started by The_Speculum, Sep 14, 2005.
  1. The_Speculum
    The_Speculum
    Apr 2, 2005
    276
    I've decided to upgrade from a very low quality speaker cable :blush: to a higher quality one :rolleyes:
    ... now that I will custom order the cable, a question arises...
    ...Should I use BFA plugs or should I use SPADES.
    BFA are hard to find, and I don't know the SPADES size...
    ... can anyone help me on this one? :confused:
  2. GrahamMG
    GrahamMG
    May 8, 2004
    4,459
    UK
    +194
    8mm spades (the hole size!!!) fit TAG amps, I'd stay away from BFA's personally....
  3. The_Speculum
    The_Speculum
    Apr 2, 2005
    276
    Do SPADES come in many different sizes and shapes?
    ...how can I check what is the right one?
    ...when you mentioned "8mm (the hole size)", is that the only thing that matter?
  4. Miron
    Miron
    Sep 26, 2002
    1,433
    Vienna, Austria
    +53
    all in all, size does matter :)
  5. GrahamMG
    GrahamMG
    May 8, 2004
    4,459
    UK
    +194
    The size of cable they can accept as well........ and insulation provision.....after all you don't want them to touch......
