Should i upgrade?
Discussion in 'AV Receivers & Amplifiers' started by Tiesto, Jul 8, 2005.
  1. Tiesto
    Tiesto
    Mar 26, 2005
    99
    11
    Present set up is 4 years old now and comprises of a Sherwood rd6106 amp/receiver , Eltax liberty floor standers and centre with 2 bi polars, Eltax atomic 8.2 sub.
    I mainly use this set up for movies with a Toshiba projector, lately though i have been less than impressed with the movie soundtracks , i need to crank up the volume to about 75% of the amps output :eek:
    I have just disassembled all the cabling and made sure that all voltage carrying cable is not near the speaker cables (Gale XL 315 BI ) and took the gold plated banana plugs apart to remove any possible oxidation.
    Is it time for an upgrade on the amp ( whats the views on this amp?) or Speakers or go the whole nine yards and start saving.
    I really would appreciate input on this as when i first set this up it was my pride and joy ( dont laugh, i was on a strict wifey watching budget) :) :smashin:
  2. deanym
    deanym
    May 29, 2004
    1,833
    +143
    Hi Tiesto,
    My first kit was all Richer Sounds too!! :)
    I would start saving as improving each little section won't bring about the changes you'd hope for.
    A new amp and speaker set would be the way to go (depending on budget) and there's many suggestions regardless of budget on the forums. :smashin:
  3. chedmaster
    chedmaster
    Jan 29, 2005
    2,661
    68
    +28
    i had almost the same kit!!! same amp, and im assuming liberty 5+'s? dont upgrade the libertys i tried better speakers with that amp, no better really, the amp is your weak spot. The upgrade i did was still richer sounds, the cambridge audio azur 540r, and it is in a different league to the sherwood. I couldnt believe it when i upgraded, as i thought the amp was good and that the "cheap" speakers were the problem, but a year on and i have no desire to upgrade the libertys.
  4. chedmaster
    chedmaster
    Jan 29, 2005
    2,661
    68
    +28
    ps when i had this amp i was a bit disappointed with the whole surround sound phenomenon, not hearing much from the rear effects etc. now i cant live without it! Everything is so much clearer and direct, no muddy dialogue that i use to get from the sherwood, and music, well, WOW.
  5. Tiesto
    Tiesto
    Mar 26, 2005
    99
    11
    Thanks lads :smashin: think i'll upgrade the amp first and hear how it goes, i quite like the Liberty speakers and more importantly so does the wife :D
