Question Should i upgrade to budget 4k?
Discussion in 'General TV Discussions Forum' started by J-Rock, Dec 3, 2018.
  1. J-Rock
    J-Rock
    Sep 26, 2007
    530
    28
    Ayr
    +37
    Hi all,
    Looking for a bit of advice. I currently have a Samsung PS60F5500 Plasma and was considering a new 4K TV, i dont have a great deal of cash so was looking at the budget 4k TV's. Do you think it would be worth the upgrade? If so to what? I was looking at:
    Samsung UE65NU7100
    Hisense H65A6200UK
    Thanks for any help you can provide.
    J
  2. EndlessWaves
    EndlessWaves
    Apr 7, 2008
    13,482
    Norfolk
    +2,432
    How much of the stuff you watch is available in 4K and how close are you sitting to the TV?
  3. J-Rock
    J-Rock
    Sep 26, 2007
    530
    28
    Ayr
    +37
    Not a great deal will be the answer to that. I have sky and xbox so would be some content on that. Probably mostly be used for xbox.
    Only about 7 to 8 foot away.
    J
  4. EndlessWaves
    EndlessWaves
    Apr 7, 2008
    13,482
    Norfolk
    +2,432
    I wouldn't be in any hurry to upgrade then, give it another five or ten years.
  5. J-Rock
    J-Rock
    Sep 26, 2007
    530
    28
    Ayr
    +37
    Thanks for the advice.
