Should I upgrade the speaker cable on the denon M30
Discussion in 'Home Cinema Speakers' started by aldavies, Apr 17, 2005.
  1. aldavies
    aldavies
    Can anyone tell me whether upgrading the speaker cable on the denon M30 mini system would be worthwhile. I already have slightly better cable that the one that came with the system, but this was only about £1 per metre.
    I have a small amount of chord carnival silver plus left from my main system, which would be enough, but I don't know whether this system can take banana plugs. Excuse my ignorance, because I don't know what thes connectors on the denon are called, but they have the little plastic pieces that you lift up to open, slot in the wire, and put back into position. Are there any other connectors I could use for this system? Any help would be appreciated.
  2. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,545
    Near London.
    +208
  3. Dfour
    Dfour
    Jan 19, 2004
    4,091
    71
    Bracknell
    +86
    Thanks Eviljohn ive been looking for something like these for a while as the cable from my presence speakers is a little to big to stay in the spring clips on my 1400.
  4. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,545
    Near London.
    +208
    Not a problem mate, using them to actually enable the connection is bound to be of better quality than the cable having fallen out onto the floor. ;)
  5. aldavies
    aldavies
    Thanks for the advice Eviljohn 2. I may just get some of them.
