Answered Should I upgrade GTX 970 to 980ti..........
Discussion in 'Computer Components' started by petrolhead, Mar 31, 2016.
Tags:
  1. petrolhead
    petrolhead
    Mar 29, 2002
    4,817
    87
    Newcastle
    +120
    .............or should I now wait for Pascal?
    Card used for playing games at 3440x1440 but also after a good Cuda score for Adobe Premier Pro
  2. Best Answer:
    Post #8 by offitmassive, Apr 3, 2016 (1 points)
  3. EndlessWaves
    EndlessWaves
    Apr 7, 2008
    13,206
    Norfolk
    +2,340
    It's a fairly minor benefit of 40% or so, unless you're in a situation where you really need that I'd wait another year for the Pascal/Polaris version of the 980ti/Fury X to be released.
  4. petrolhead
    petrolhead
    Mar 29, 2002
    4,817
    87
    Newcastle
    +120
    Thnaks
  5. smithersmk
    smithersmk
    Nov 25, 2006
    235
    Milton Keynes
    +96
    Waiting for Pascal is the sensible option...However....
    I've just upgraded from a 970 to 980ti. I had recently updated to a 1440p/144hz monitor and wanted to make the most of it.
  6. damanc
    damanc
    Mar 26, 2008
    33
    11
    UK
    +4
    £550 odd for around 34% performance bump.......
    The sensible choice is Pascal imo
  7. shaz2sxy
    shaz2sxy
    Mar 17, 2016
    91
    11
    Newcastle
    +9
    I would wait for Pascal
  8. petrolhead
    petrolhead
    Mar 29, 2002
    4,817
    87
    Newcastle
    +120
    I was looking at about £430 for a used one and get about £200 back for my existing GTX 970
  9. offitmassive
    offitmassive
    Sep 30, 2009
    2,093
    Hereford
    +175
    Best Answer
    Neither tbh. I'd sell the 970 and get a r9 390 . If it's for 1440p why would you want to spend (I predict more silly nvidia pricing) silly money for a pascal gpu when the 390 does it easy. FYI I just tried bf3 at ultra 1440p and get 130+fps.
    I personally recommend the sapphire nitro r9 390 if it will fit in your case as it's quite a size but it's worth it. Runs cooler than my previous msi 970 , doesn't buckle on ARK like my 970 did . Save your money and get the 390 NOW !
  10. Cameron583
    Cameron583
    Jan 3, 2014
    1,167
    +234
    For 3440x1440 you'll want more power than a 390, since it's a re-badged 290(x). Running cool isn't what it's about, it's the heat it dissipates. The 970 dissipates less and as such, runs quieter/cooler depending on the fan profile. Best to wait for the next generation of NVidia and AMD cards.
  11. offitmassive
    offitmassive
    Sep 30, 2009
    2,093
    Hereford
    +175
    Sorry I thought it was just 2k resolution. My bad
  12. Cameron583
    Cameron583
    Jan 3, 2014
    1,167
    +234
    2K resolution is 2048x1080 by definition, and is more commonly referred to as 1080P (1920x1080). The same with 4K, it is by definition 4096x2160, however is more commonly referred to as 3840x2160.
    I don't mean to be a pain, however it's a really annoying habit most YouTubers use and it's just not true :p
    2560x1440 (WQHD) is more of a 2.5K since it's a quarter of the amount of pixels of 5K (1080p is 1/4 of 3840x2160)
