I have a Yamaha A3070 currently and running a 5.2.4 setup. It does everything I need it to do, although I wish YPAO can do more for my room. I have the option to add surround back also if I want to.
Now, there is a used Arcam AVR550 and Anthem MRX-1120 in market. I find myself having upgraditis, thinking whether these highly regarded AVR can make my surround setup sound better (I'm more into the surround effects than the bass).
Yesterday I auditioned both of them albeit in different locations and rooms, so they are not an equal comparison. They both sound good. I'm particularly impressed by the Anthem. It seems to make the speakers disappear better. But I'm not sure if I'm just hearing the room because the room with the Anthem is significantly larger with little treatment. The room with the Arcam is smaller but has light treatment. Both AVR did not have room correction set.
I have a very small dedicated room so I always wonder if a better AVR will make the surround sound seems wider. My room is lightly treated. But I know I still have a bass reflection problem that I have plans to fix soon with bass traps. I have Dali Oberon On-Wall for LCR, Dali Zensor 1 fort surround, Q Acoustics Qi65CP ceiling speakers.
Performance is all relative to cost. I think I can get about £700 from selling the Yamaha. The used Anthem MRX-1120 will set me back £1500, around twice the Yamaha. The Arcam is slightly cheaper at £1150, but it might work out similar because of the need for additional amp to drive the height speakers. I wonder whether the difference is big enough to justify the cost. Should I upgrade or keep the Yamaha?
