Should I send it back?
Discussion in 'General TV Discussions Forum' started by Shedboyzz, Jul 13, 2005.
  1. Shedboyzz
    Shedboyzz
    My 32zp48 has right to left slope/tilt of 4mm. Doesn't sound much, but it is noticeable when any graphics appear on screen.
    Is this reasonable or should i ask for an engineer/swap?
    Opinions?
  2. Tight Git
    Tight Git
    Mar 3, 2004
    6,332
    +597
    Most modern TV's have a tilt adjustment to compensate for the Earth's magnetic field.
    Have you tried that?
  3. Nottman
    Nottman
    Dec 11, 2002
    208
    Gtr. Manchester
    +5
    No tilt control on the 32" model, I believe - only the 36", unfortunately
  4. lonewaller
    lonewaller
    Shedboyzz
    Did you get anything done about your TV - I have the same problem?
    Brian
  5. lonewaller
    lonewaller
    Just got the following answer from Toshiba
    "I am afraid that there is no adjustment for the slope of the picture as
    you described. An engineer would not be able to adjust it without
    disassembly. We have found that the large widescreen tubes are sensitive
    to changes in the Earth's magnetic field caused by the TV orientation (ie.
    which way the screen is facing compared to the way it was facing in the
    factory when it was set up). You should be able to see this yourself if
    you turn the TV through 90 degrees and then measure the slope again. In
    cases like this a threshold has to be set defining a fault condition, and
    up to 5mm is within this threshold. If the retailer were to replace the
    TV, it is possible that you might find that the replacement has a larger
    slope."
    Brian
  6. LV426
    LV426
    Administrator Staff Member
    Jul 14, 2000
    13,443
    Somewhere in South Yorkshire
    +5,852
    Hmmmmmm the joys of the "better" picture produced by CRTs. The only route to assured perfect geometry is via Plasma or direct view LCD.
  7. lonewaller
    lonewaller
    Just to confirm a posting on another thread, I rotated my TV by 90 degrees to-day to test Toshiba's info. The tilt disappeared.
    Brian
  8. per-Sony-fied
    per-Sony-fied
    Jul 24, 2005
    2,305
    +100
    :oops:
    One of several reasons for me deciding against the Tosh despite it's several strong points. A few features that Tosh could have easily implemented in thier software.
