CaptainJames
Nope, I just see blue screen.
If you see the drive version and use zoom in, you will see my red arrows, they show the lines. Every edge has 1 line. I sent it to Sony service, thats why they got me a brand new modell without questions, so i think they are noticeable. All in all there is no doubt its very hard to take a photo of them. :/
Very odd. Perhaps there is a reason why there are no other threads about it.plus it's odd that you've noticed it on other TVs too.
I am not able to see the lines from closer. Its visible only from 1,5-4 meters. The most strange things is that the lines move with picture. If i set 4:3 ratio, the vertical lines will be at the edge of the picture, If i watch 21:9 ratio film, the horizontal lines will be at the edge of the picture so they dont stay at the edge of the screen. I think its a sowftware problem.I was only just about able to see them by zooming in fully on your Google Drive photos on a large PC monitor so I think you might need to take closer, clearer photos if you want anyone to be able to view them on a smartphone.
Are the lines visible from a normal viewing distance and from all sources, including the TV's own tuner and apps ? Could be a bezel/alignment issue, but you wouldn't expect to see a single line all the way around if that was the case, plus it's odd that you've noticed it on other TVs too.
What colour are the pixels when watching normal content ?
No, i had turned that off but nothing changed. :/This isn't something I noticed, and I can't see this on your pictures on my phone. It's not caused by the anti-burn in settings?
