Real Ramona
Hi all, I have just taken up the offer to have Spotify Premium free for 3 months. First thing I did was to set streaming quality to Extreme. Now it does sound considerably better than the standard free setting. But it keeps stopping. App still running on my phone but it has disconnected from CCA and track stopped playing.
I am certain the CCA must be the weak link in the chain now. Here is what I have:
Cast to CCA with Android phone
CCA is hardwired via the ethernet mains adaptor. Plugged into a Gigabit switch which is plugged into Asus router. I am on a fibre connection , currently getting 38 Mbps.
This CCA is plugged via optical cable into opti input of a Cambridge CXA60
Could this be a problem with the streamer? I have heard about issues with CCA and Spotify before, but nothing resolved.
The device works perfectly for streaming from my Plex server I think. Though I did notice some odd artifacts at the end of a couple of tracks last week.
If the device is faulty, then would a Teufel Connector be a good replacement? Assuming I can find one.
