Should I replace it or keep it with tint issued on 65Ez1000
Discussion in 'Panasonic TVs Forum' started by Puccainbkk, Oct 3, 2017.
  1. Puccainbkk
    Puccainbkk
    Jul 2, 2007
    123
    +14
    I have ez1 awhile. I notice the blue tint coz the left side is brighter than other on the screen .
    I feel upset . Sometimes I could notice it on the other hand mostly you would find it if you don't look for it. I have ex1 about 2 weeks and it runs about over 30 hrs
    I can't say it is bother when you watch contents. If I look or that yes it is there if I don't look for that I could not really notice but I already have known and noticed it
    Anyone has any experience about it ?
    Will it go away or less after awhile or I should get the new set.
    I worry if I get replace I may bet worse more than the one I had..
    I put some content that I took picture before. I could not see it .
  2. raymondo77
    raymondo77
    Aug 14, 2013
    6,052
    3
    Reading, Berkshire
    +8,766
    Unfortunately it won't go away, so you could try a replacement. In my experience, most OLEDs have some sort of tinting though.
    2017 Oled Yellow/Red Tint
  3. Puccainbkk
    Puccainbkk
    Jul 2, 2007
    123
    +14
    thank you so much. I wait from Panasonic to contact now.
  4. encaser
    encaser
    Mar 15, 2001
    4,998
    Suffolk/Essex/Srebrenica
    +2,580
    I think you're doing the right thing Puccainbkk, once you've seen it you will always be looking and will spoil your fun.
