should i have a smart meter fitted?
wongataa
1. I should get a new one that works if i in the future switch suppliers right?
Hopefully. Make sure it is a SMETS2 to be sure of this.
2. I have to unplug all electrical equipment before they install it right ? does that include washing machine freezer and cooker? dont fancy rewiring the 10mm cable of the cooker
Just turn the power off at the consumer unit.
3. Is it wifi or mobile network the meters use?
Mobile networks.
4. can you also read the meter or does it just come output all the info to the smart display?
5.paranoid could i experience any tripping problems due to the fact my electric and gas meters are right next to my consumer unit?
The meter won't affect your consumer unit. If that happened you would have heard about it by now.
Trollslayer
Once concern is that if a smart meter uses 2G mobile how long will the phone networks support that?
It won't be for quite a while but that could mean replacing a lot of smart meters.
Recent ones should be 3G at a minimum.
ufo550
Right might switch to a tariff that requires that i have smart meters installed so got a couple of questions. Im with Scottish power
  5. paranoid could i experience any tripping problems due to the fact my electric and gas meters are right next to my consumer unit?
many thanks
My mate was just telling me he was on scottish power they come round and fitted the smart meters and the installer inspected his old boiler and deemed it dangerous and cut off his gas supply. My mate then worried called a gas engineer round who thoroughly tested and inspected it and siad there was nothing wrong and reconnected it. problem is the gas fitter cost £120 to test and reconnect.
After all that the smart meters never worked and he had to supply readings anyway
5. I have read of such issues, but not everyone has the same problem.
Edit; one of the other reasons for a meter tripping an RCD, is loose connections. Several cases of the supply & meter terminal connections not being tightened enough, by the meter installer. When I replaced consumer units, and would go back a short while later and re-check my meter tail terminations.
You have to remember, most not all meter installers, are just that. They have limited training, but if they think there's an issue, they're required to act. If I was your friend, I would of sent the gas engineers report to his supplier, and sort compensation.
Trollslayer
I have a 4G phone but I know that initially 2G smart meters were installed around the country for quite a while.
I'm not buying a 2G phone to check!
imightbewrong
2G will outlive 3G - it's used for quite a few low-bandwidth use-cases.
imightbewrong
Arrrrrrrrrgh! "incentivising"?
We speak English, it is "motivating"! :mad:
Language evolves. Also motivating is not the same as incentivising.
imightbewrong
One is trying to encourage someone to do something better, the other is kicking them up the arse. Is that correct?
No. Incentivising means giving an incentive - for instance giving a tax incentive to get a green vehicle. This is incentivizing green vehicle uptake. It's not the same as motivating, though there can be overlaps.
sergiup
Smart meters 🤦🏻‍♂️ great idea, but... Mine stopped sending any readings since January. Smart display thing continously rebooting since around the same time. And amusingly, they only register readings once a month, kinda defeating the point of making them so easy to get. They've finally decided to change "some things" and change reading frequency to daily. That was yesterday, no change yet.
Magically fixed itself a couple of days ago; previous bill cancelled, new bill issues with real readings (actually consumed about £20 less). Hurrah! For now...
imightbewrong
Fined for missing a 2017 deadline? The wheels turn slowly in this industry.
tredman
O2 Telefonica committed to keep their 2G network (which smart meters in the south / mids use) going for 25 years after roll out. 2G is used for a ton of M2M stuff and will be around way after 3G - which is already been removed in some countries.
Smart meters in North / Scotland are not GSM and use a special Archiva low frequency radio network (around 900MHz IIRC)
KyleS1
2G will be around for a long time. Too many products committed to it.
Trollslayer
It is only now that there is a serious effort to get rid of POTS (analogue) phones, that has taken a while.
outoftheknow
Ah that is where we are ahead here then since our National Broadband Network (NBN) uses exisitng copper phone lines for the FTTC parts. 18 months after the NBN is connected the POTS is turned off.
2G here wasn’t used in much like there - smart meters are only just being rolled out here and all have 3G as does other stuff.
even if we had things using 2G it’s too bad. All turned off :)
maddy
Yes, BT has tried several times to turn off the PSTN and move to VOIP but for a variety of reasons didn't push on with it.
One of the drivers behind finally doing it is the impending expiry of the 25 year sale/leaseback of their buildings - they don't want to renew them and maintain a huge property portfolio of mostly empty buildings.
Buying EE enabled them to do this, the tech is based on EE's IMS platform allowing the closure of about 3,000 exchanges and potentially seamless landline/mobile services.
x3j3UKN
So finally succumbed and have my meters booked in for the 21st July...
To be honest i thought I’d hold off for longer!
Podcast: LCD TVs for Movies, Laser Projectors, RIP Ennio Morricone, AV & Movie news, B+W Matt Damon
Trending threads
Latest News
QDC Blue Dragon earphones on sale in UK
  • By Andy Bassett
  • Published
TV licence fee now applies to over 75s from 1st Aug
  • By Andy Bassett
  • Published
New H.266 video codec promises 50 percent data saving
  • By Andy Bassett
  • Published
Toshiba launches UL20 4K HDR TVs from £299
  • By Andy Bassett
  • Published
LG GX soundbar launches in UK
  • By Andy Bassett
  • Published
