tripper4k
Dear avf member,
I have been looking for some Amp for a while, due to the feeling that on the same song. When listen to stereo mode, the R7 seem to deliver more detail sound also more bass(I have to lower the sub volume or turn it off depending on the song), on other hand when i listen to music on all channels (muti ch stereo) the front R7 seems to produce less bass and detail than the surround r3.
This is making me wonder if the front speaker need more power to properly produce the better sound. I do not really crank the volume up that much, i did not notice any pop or weird sound, Just quality i guess. The room size is a big space, my setup is in the open space. 3.2 meter width and 4meter length. The speaker is around 2.4 meter away from me, surround is just 1.7 meter.
, my system are listed below
Front Kef R7 with Aq rocket 88 cable
Center Kef R2c with Aq rocket 88 cable
Surround Kef R3 with unbranded cable
AVR Marantz sr7015
Sub REL Ht1003 with Aq irish red cable
I mainly listen to steaming music, many gens. Mostly soundtrack from some movie or some youtube mv(mostly they sound bad)
i have been advise to use buy anthem mca 525 over rotel 1585 and use my avr pre-out to pass signal to the amp. Im thinking about this option a lot, but
in the end i might still want to try the pre(av7705/7706) or other brand if it fit the budget.
so if i really need to amp, i got 2 option.
one is keep the avr and add some amp.
second is sell avr, buy new pre and new amp (sigh) it will cost me a lot more.
what do you guys suggest?
r7 need an extra amp? If so what choice should i go with.
hope I can help here.
Best regrad and thank you in advance for any comment.
Tripp
AVR Marantz sr7015
Tripp
