Should i get a scaler??
Discussion in 'Plasma TVs Forum' started by nonikandola, Dec 28, 2004.
  1. nonikandola
    nonikandola
    i have a pioneer435fde at the moment. after doing a bit of reaserch ( i mean a bit) i think it could be a good idea to get a scaler to improve my images. am i right in this idea. So i worndering...
    1. what improvement will i see
    2. can u suggest a scaler for under 250quid
    3. how do you install one.
    cheers
  2. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    Nothing at that kind of money is likely to perform any miracles, though if you do not have an HDMI DVD player, a 2nd hand iscan ultra might be worth a punt. There is a slight anomaly in it's digital output which might prevent it working on your screen though. I believe it puts out 572p or something digitally, that would be a pain. A true scaler is nearer £7-800 for the basic LUmagen or iscan HD. Then you can get serious.
