should i get a multi-region pana e85?
Discussion in 'Blu-ray & DVD Players & Recorders' started by Halloween Jack, Nov 13, 2004.
  1. Halloween Jack
    Halloween Jack
    Sep 27, 2004
    275
    16
    or should i just get a normal one, £30 cheaper, as on my current dvd player i only had to type in a code to make it multi-region. will this work with the e85?
  2. Siamese Cat
    Siamese Cat
    May 31, 2004
    619
    46
    London
    +137
    No it won't.
    Panasonic machines are a bit more difficult tp make muti region. You can hire a special remote to do it but it's probably easier to buy a M-R one in the first place.
    Just bought an e-85, multi region from Richer Sounds for £399, great machine, great price (though I bet someone posts somewhere even cheaper in the next 10 mins)
  3. dempsey
    dempsey
    The only snag with buying one already Multi-regioned is the fact that it may possibly say just that on the receipt so come warranty repair time could come back to haunt you.
    D
  4. Halloween Jack
    Halloween Jack
    Sep 27, 2004
    275
    16
    in that case, is there a way of copying different region dvds on my pc to make them region 2? or is this dodgey ground?
  5. emmaroids
    emmaroids
    Oct 19, 2004
    17
    mansfield
    Siamese Cat which richer sounds did you see this price at, i have been into the one at nottingham today and they would not budge from their price of £449.
    many thanks
  6. norfred
    norfred
    May 2, 2004
    289
    bromley
    +9
    visit the richersounds website and print the price list. The local brsnch should then honour that price. Got mine that way from Croydon.
    Norfred
  7. Graham
    Graham
    Nov 21, 2000
    779
    63
    London
    +250
    it's in this month's what hifi for £399 too, so tak that in. Or print off a rival website's page and they'll beat it by £10.
  8. emmaroids
    emmaroids
    Oct 19, 2004
    17
    mansfield
    thanks for the tip guys went back to richer sounds today in nottingham and got them to price match total digital in birmingham, ended up getting it for £389 after they knocked there price promise £10 off aswell. :thumbsup: :thumbsup: :thumbsup: :thumbsup: :thumbsup: :thumbsup:
