should i get a fan ?
Discussion in 'Xbox Forums' started by weaponx_uk2003, Aug 4, 2006.
  1. weaponx_uk2003
    weaponx_uk2003
    Jan 17, 2005
    1,724
    +98
    hi shuld i get a fan for my xbox 360 and if so which one is best
  2. Tetlee
    Tetlee
    Jan 21, 2004
    20,321
    Taunton
    +4,821
    Well personally I wouldn't bother, seems a waste of money to me as surely the console was tried & tested to run at the temperatures it reaches.
    Just my opinion & obviously it gets pretty damn hot where I am:devil:
  3. SheldonLavine
    SheldonLavine
    Jan 31, 2006
    391
    essex
    +16
    save your money, the add on fans are a bit gimicky imo. I would just ensure you site the console in a well ventilated place.....give her plenty of room to breathe :smashin:
  4. redmarkred
    redmarkred
    Jan 25, 2006
    1,239
    +88
    Isn't your 360 loud enough without adding more fans :confused:
  5. gamingboy
    gamingboy
    May 23, 2006
    1,681
    63
    +240
    I don't know about anyone else but I stand mine vertical so as it can breathe all around. The heat dissipates better for me.
    My console becomes a lot hotter when it's placed horizontal. The top and bottom would get hot. I'm sure other people have it horizantal and it's fine but mine crashed.
    Mine is always in the same place with plenty of ventilation but I found that works better. So try chaging your setup maybe if it's getting hot/crashing and see what happens :thumbsup:
  6. W1zz
    W1zz
    Jul 16, 2002
    1,303
    +171
    I'd have thought Microsoft would have designed them to run at much higher temperatures than we would get to in the UK. What about all the Yanks that have them in their trailers parks. (Mention that to them on XBLive and then run for cover).
    Ooohh! :rolleyes:
  7. Tetlee
    Tetlee
    Jan 21, 2004
    20,321
    Taunton
    +4,821
    Just thought, SS4 will be back soon so expect to hear alot of hype about how fantastic & essential an external fan is.
  8. mminghella
    mminghella
    Dec 16, 2005
    1,067
    48
    Liverpool
    +34
    ...so long as it doesn't have a blocky head :devil:
  9. dodger747
    dodger747
    May 5, 2005
    2,976
    Liverpool
    +209
    Haha, just spit my coffee all over my keyboard when I read that:rotfl: :rotfl:
    Personally I wouldn't bother with a fan, for me I can see no advantage in using one. Have a search there has been plenty of debate on these external fans already...:thumbsup:
  10. rio1981
    rio1981
    Feb 25, 2006
    4,788
    Worcester
    +837
    For a minute I thought you meant the cheerleading-type fan, pom-poms and all! I could always do with a bit of support in a tight match every now and then :clap:
    Much as everyone says, making sure the unit is ventilated is the most important thing - so don't go wrapping it in a jumper, for example...
  11. Tetlee
    Tetlee
    Jan 21, 2004
    20,321
    Taunton
    +4,821
    I take it a t-shirt should be ok though, right? Works out alot cheaper than a replacement case;)
    Off topic but good luck with your move rio1981.
  12. rio1981
    rio1981
    Feb 25, 2006
    4,788
    Worcester
    +837
    hehehe... I would thank you mate but the button's fallen off today :D Literally just completed a few minutes ago so I'll need to rush home from work soon to start the fun stuff - lugging around the heavy stuff.
    Cheers Lee :smashin:
