Should I foam line the inside of a 250ltr Fi Q18 sealed enclosure?
Discussion in 'DIY Speaker & Subwoofer Building' started by Tyler Durden, Sep 11, 2012.
  1. Tyler Durden
    Tyler Durden
    Apr 18, 2005
    5,609
    Shrewsbury, UK
    +327
    I'm starting the build of a pair of 250ltr sealed Fi Q18 enclosures and was wondering whether I should be lining the internal walls of the boxes?
    I am going to be using some wadding like this >>recycled plastic insulation<< in the box, but should I also line the walls with some egg box foam or similar?
  2. Ashmanuk
    Ashmanuk
    Sep 7, 2007
    1,522
    kent
    +296
    I used the normal wadding, at first I put a lot in but ended up putting it around the walls of the cabinet only.
    Wadding is easier to adjust the tuning of the sound I think than foam, pyramid foam is very good for normal speakers as it affects higher frequency's more.
    Will you be posting any pics of the build :)
  3. Tyler Durden
    Tyler Durden
    Apr 18, 2005
    5,609
    Shrewsbury, UK
    +327
    Can you put a link to the wadding? Or perhaps guide me where to find it?
    Yes, photos and a thread will appear soon.
  4. Ashmanuk
    Ashmanuk
    Sep 7, 2007
    1,522
    kent
    +296
    I got my wadding from FABRIC WAREHOUSE
    it was cut off a roll I got the thickest I could get, I think it was around 18-20mm
    The Bay have some as well.
  5. Tyler Durden
    Tyler Durden
    Apr 18, 2005
    5,609
    Shrewsbury, UK
    +327
    Got 12m of a 200g wadding from Dunelm. Sorted.
