Should I enable xvYCC on my amp?
tommyb1
What is the xvYCC setting for?
I currently have it disabled but should I enable it?
Etienne A
This might help ... but basically yes (i have on mine) if your display & source support it then 100% yes - and if not it should not create any problems ... your amp should not explode if you try !!
namuk
leave enabled it will only kick in when you have a blu ray/hd dvd player that has it:thumbsup:
if you talking about 1.3 deep coulor that is:smashin:
