Should I earth my equipments chassis?
Discussion in 'Cables & Switches' started by ajt, Apr 25, 2005.
  1. ajt
    ajt
    Jul 29, 2004
    24
    I'm going to build some new cables for my kit as part of a whole re-wiring / tidying up exercise. Currently all my kit just takes 2 core flex, ie no earth. If I weave some new cables with an earth core should I connect it to the equipments chassis or just leave it dangling (insulated of course)?
  2. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,545
    Near London.
    +208
    Unless you already have a ground loop problem then just leave it as is. At best you won't notice any difference, at worst you'll induce ground loops which are bad. :)
  3. ajt
    ajt
    Jul 29, 2004
    24
    Cool. Thanks for the advice.
