Should I change my rears?
jlcrawford
I have just got a Lex MC1 and separate Rotel amps. In the Lex setup it has the option for small dipoles as "Sides" but no dipole option on the rears.I currently have the KEF thx pack with an extra set of dipoles as rears- should I change the rears and what would you suggest I change to.
TIA
Phil Hinton
Editor
Staff member
Jeff,
Does it sound alright with dipoles on the back? I would have thought the Kef TDM's would be fine in the rear back role for movies, don't know about Logic 7 though.
According to THX Ultra 2 spec they suggest direct radiators on the rear channel, so if you went that route you cound add two the same as the front 2 in the package you have.
I don't think however you will have any problems with the TDm34s on the rear...........unless they sound wrong to you?
