M
mrmattis
Hello
I have bought a HK DVD 25 with component/progressive out. My ASK C60, doesn`t have component in, not even through vga
Should I change my projector for a Panasonic PT-AE 100, with component in ?
What do you think will give the best picture:
ASK C60 (1100 ansi/XGA), and s-video, or Panasonic with component in ?
My screen is 180 * 180, and the viewing distance is about 280 cm.
The main use is DVD, mostly pal.
Should I change, or should I stick with my ASK projector ?
mrmattis
mrmattis
