Should I buy these Monitor Audio speakers
FIRETRAP18
Hello everyone I need your help and input about some speakers. I currently looking to upgrade my speakers after years of having the same set.
The setup I have now is
Wharfedale 9.1 fronts
Wharfedale 9.cs centre
Wharfedale 9.0 surrounds
Wharfedale sw250 subwoofer
I have been offered this set up for £550
Monitor Audio BX5 fronts
Monitor Audio BX centre
Monitor Audio BX2 surrounds
Monitor Audio BXW-10 subwoofer
Would this setup be an upgrade from current setup?
Gasp3621
The price sounds bit high? Maybe other members knows better the value of older ranges. @password1 probably has good idea.
The BXW-10 sub is garbage. I think your Wharfedale sub is better so you should buy the speakers only with reduced price! There is no "matching" required with subwoofer and speakers so use the SW250. I have owned the BX5 with newer Bronze centre and they are certainly good speakers which should sound quite different to Wharfedales.
FIRETRAP18
This is the prices hes listed the speakers individually
Bx5 floorstanders £220
Centre £100
Surrounds £85
Sub £225
Gasp3621
The center channel is overpriced as you can get the newer Bronze Centre for same price.
If you have speaker stands for Wharfedale 9.1s would you consider standmount model also? You could get the newer Bronze system cheaper than those you mentioned. There isn´t going to be that big difference between the larger standmount model (B2) to floorstander (BX5 / B5), with movies the subwoofer takes care the low end so you won´t hear much difference. The tower route would be more for the looks.
Bronze 2 - 150£ : Monitor audio Bronze 2 Bookshelf Speakers | in East Dulwich, London | Gumtree
Bronze 2 - 150£ : Monitor audio bronze speakers | in Attleborough, Norfolk | Gumtree
Bronze Centre - 99£: Monitor Audio Bronze Centre Single Black | eBay
Bronze BX1 (not BR), you could get these for 50£ or so for surrounds:
So i think 300£ could be possible for the 5.0 and you would get newer speakers than the person selling those BX Bronzes for you.
FIRETRAP18
So the ones you listed are they all newer and better than what I'm being offered?
Gasp3621
Yes newer generation (about 4-5years newer) the Bronze 2 and Bronze Centre. The Bronze BX1 (it says Bronze BR but it´s BX really) is older as i couldn´t find matching newer B1s, but you can mix those without issues. The front three is same which was used in this AVF review, read it up:
password1
way overpriced.
the newer bronze 5g centre were £99 brand new
the bx5 at £220 is more than im selling my newer monitor 200
password1
I'd be looking at £200 with £40 worth of cables.collected from ws11.
If you're interested I'll post a forsale or you post a wanted ad.
password1
The Monitor 200 av package were reviewed on this forum and the same package withhout the sub can be bought for £549 brand new on ebay. You could use your existing sub.
ben16v
i went WH9.1 all round in 5.0 to bronze 2 fronts, now have bronze 6 front witht the bronze 2 as rear.
tempting package that though but i would look to the next level up.
it would be an upgrade but the WH range are very good for the money
password1
password1
The Monitor 50s and 100s are bookshelves.
The mass 2 are satelites. You could ask and change them to bookshelves.
Gasp3621
@FIRETRAP18 if you don´t require floorstanders the items i linked would cost about 300£ and be step up from the Monitor range. All you need is speaker stands (600mm) for the main speakers Bronze 2s. With sub on you won`t hear difference. I heard those in store and the amount of bass weren´t any less than with the slim towers (BX5). That is usually the main reason going with towers, although if it´s the looks then i understand. Shame you missed the last Bronze 5s. They were going crazy cheap like 299£ from 550£ normally i think.
FIRETRAP18
No I'm not specifically after floorstanding speakers, I just saw them and thought it was a good price. I was initially waiting for a good price on a pair of b&w book shelf speakers and have the wharfedale 9.1 as rears for the time being
Gasp3621
Well if you want B&W speakers then by all means get em. They are now on sale, few still available cause they just brought out the S2 model:
The 606 would be Bronze 2 size and step up in size from Wharfedale 9.1 . You would be very fine just upgrading the front three. As i said you have decent subwoofer so keep using that SW250 and consider something larger in future, just keep in mind that subwoofer placement can make big difference. What i have read about the B&W 600 range is that they are more on the brighter side so i would assume quite opposite to Wharfedales which are likely warmer and more laid back.
FIRETRAP18
When you say bright, what does that actually mean? I'm not clued up with all this. Also having the 9.1 as rears it wouldn't be a problem would it sound wise?
Gasp3621
I meant the high frequencies. Brighter sound. How can i explain that, haha. This is why it would be important to listen before buying or make sure you have return period if for some reason it`s not for you. Applies to any speaker brand though.
No it won´t be problem to have the 9.1s as surrounds. One member got those with Kef R system and perhaps still has. Not optimal, but not a problem for the time being. For subwoofer there is no matching required so zero issues on that.
Which av-receiver you have?
FIRETRAP18
I have the denon avr 2113
Oculus Quest 2 VR headset + Rotel A14 MkII Amp Reviews & Best of the Month
Latest News
Hisense increases Laser TV sales following Euros
  • By Andy Bassett
  • Published
Samsung Smart Start offer grants access to premium TV apps
  • By Andy Bassett
  • Published
DS Audio launches third generation DS003 optical cartridge
  • By Andy Bassett
  • Published
JBL announces L52 Classic speaker and L75ms all-in-one
  • By Andy Bassett
  • Published
Sony Bravia XR X95J TV range gets 65-inch model in August
  • By Andy Bassett
  • Published
