Should i buy a JVC DLA G10E ?
Discussion in 'Projectors, Screens & Video Processors' started by Napoleon, Jan 9, 2002.
  1. Napoleon
    Napoleon
    Jan 1, 2001
    I know absolutely nothing about projectors,but have wanted to have a larger image than my 36" widescreen is capable of,for dvds,and only dvds.Does anyone have any thoughts on this projector.the specs say it has a contrast ratio of around 250:1,which is low compared to the latest models.Will a black and white film be grey and whitish?.Any comments would be appreciated.Thanks.
  2. Roland @ B4
    Roland @ B4
    Apr 11, 2001
    2,238
    Reading.
    +32
    Not unless it is very cheap.
    These were very noisey projectors.
    They did have interchangable lenses so check that before (or you chould end up with a smaller image than your 36" tele.
    DILA projectors need a lot of setting up to do them properly. The older ones just didn't hit the mark though.
    Contrast of 250 is about average for a presention LCD projector.
  3. Napoleon
    Napoleon
    Jan 1, 2001
    Roland,many thanks for the reply.I think i should avoid doing what i usually do,and check out the options properly.The projection world is a complicated one,so i'll go through all the magazines,and build up better background knowledge.Thanks again.
