Should i but the philips dvp5960 or dvp5980
Discussion in 'Blu-ray & DVD Players & Recorders' started by rd100, May 1, 2007.
  1. rd100
    rd100
    May 26, 2006
    237
    +13
  2. chris57
    chris57
    Aug 25, 2006
    1,149
    UK
    +157
  3. WeegyAVLover
    WeegyAVLover
    May 3, 2007
    4,862
    Scotland
    +1,892
    Was at Costco tonight and the Philips DVP5980 was on sale for £58.73 inc vat. Not bad...
    My questions are 2 fold:
    1. Why is HDDVD so much cheaper than Blu-Ray?
    2. Am I right in thinking this dvd player plays HDDVDs and has a HDMI output? I checked the box but never gave any details nor was there a display model.
    PS - This is my first post on this site WooHoo :suicide:
  4. aniki
    aniki
    Nov 27, 2006
    598
    +74
    It does have a HDMI connection, although:-
    This is not a HD DVD player. It will only play regular DVD discs.
    For HD DVD you will need a dedicated player.
    Unscrupulous marketing often describes upscaling players as HD, although they are in fact, not.
  5. WeegyAVLover
    WeegyAVLover
    May 3, 2007
    4,862
    Scotland
    +1,892
    I thought that was the case i.e. upscaled to HD but not able to play HDDVD's. I also agree with the marketing ploy... They did it with HD TVs when they weren't HD at all. They will use any loop hole to make you buy something you think is what you want but is in actual fact a fraud... Cheeky Monkeys
  6. dib44
    dib44
    If I wanted a true Philips HD DVD player which one should I go for guys ?
    Cheers.
    dib44
  7. aniki
    aniki
    Nov 27, 2006
    598
    +74
    Philips dont make HD DVD Players.
    Your only options are Toshiba or the XBOX 360 Add-On.
  8. dib44
    dib44
    Cheers for that looking at the cheaper option the Philips 5980 looks a good inbetweeny then.
    Many Thanks
