Should I bother upgrading my speaker cables?
Discussion in 'Home Cinema Speakers' started by Godfather, Apr 22, 2003.
  1. Godfather
    Godfather
    Feb 12, 2001
    2,223
    63
    Edinburgh
    +224
    I've been continously upgrading my AV hardware over the past 4 years but am still using QED original speaker cables. Am I likely to notice any difference by upgrading to something a bit more expensive, say around £10 per metre?
  2. TheBigApple
    TheBigApple
    Dec 10, 2002
    664
    In my cage
    +13
    The only definate way to tell would be to have two identical systems each using the two different cables, both playing the same source. You would then need to be blindfolded and have someone switch between the two systems not telling you which one you are listening to. Then you could choose which one is the best.
    The other option is to spend the money anyway and let your subconcious mind tell you there is an improvement and that you havn't wasted your money.
    Sorry to sound so bitter but this is something which I've bought into and wasted money on in the past only to find no noticeable improvement.
  3. Ian J
    Ian J
    Aug 6, 2001
    25,528
    +4,906
    I wouldn't have thought that it would be a cost effective upgrade, especially for the rears. A more effective way to use the cash (assuming you were intending to recable the rears as well) would be to spend the money upgrading the rear speakers instead.
  4. deckard
    deckard
    Dec 4, 2002
    425
    16
    leicester
    Tricky this one, I've some sympathy with Ian's point of view. However, I upgraded from QED Qudos to Chord Rumour (~£10/m) a few years ago and the difference was far from subtle.
    See if you can get a nice dealer to lend you some cables for a trial. Obvious I know...
  5. Godfather
    Godfather
    Feb 12, 2001
    2,223
    63
    Edinburgh
    +224
    Thanks for the comments. I wasn't going to re-wire the rears, just the fronts and centre.
