Should I bother to upgrade ?
zen200
Current System:
Coolermaster black case
600 watt Corsair psu
ASUS m2n32sli - deluxe wifi
AMD Athlon 64 X2 2.8 GHz Processor
4 gb ram
zotac 8800gt 512mb card
nvidia 6600 256 card
lg dvd rw drive
500 gb sata 2
400 gb ide
Sound Card ?
Was thinking of buying this lot in replacement ?
NEW AMD FX BULLDOZER QUAD CORE CPU 16GB DDR3 1333 RAM
what do you all think ?
Good or Bad or Have you any other ideas which are a similar price ?
zen200
oops
Just use it to play c&c and photoshop and web surfing and HD films and music.
I have sources the above fleebay items for £190 now so even cheaper.
EndlessWaves
I would have thought your current processor is sufficient for most of that, photoshop is likely to improve and possibly C&C if it's a recent one.
As to an alternative, consider an i3 processor or perhaps look at a different upgrade entirely such as a Solid State Drive.
mdbarber
one thing i would say to anyone considering upgrades is don't consider a mainboard that doesn't have at least the following, PCI-E v2 or 3, SATA 6GBs
OFNEP
yes you will see the difference with bulldozer coming form Athlon, If you have the money go for it.
Don't buy the ebay bundle its not a good value for money. The actual cost of the mobo and cpu is <£140 and 8 gig is more than enough for your use(roughly £40 for quality corsair ram). the most ram hungry application you are using is Photoshop and believe me 8 gig is enough for that. I have used photoshop to edit a few RAW files on on 4 gig machine and it was fine. 16 gig is overkill. also the ebayer seems to be using an unbranded ram be careful with those components don't hesitate to pay extra for a more reliable ram with lifetime warranty.
