Should I biamp my Kef 2.2's?
Discussion in 'Home Cinema Speakers' started by nathan_silly, Sep 14, 2003.
  1. nathan_silly
    nathan_silly
    I have four identical 2 channel poweramps in a 7 channel system (one amp is biamping the centre) It shouldn't be too expensive, as I'll only need a any decent two channel poweramp for rears - move the amp from the rears to the mains, buy another length of speaker cable and bananas.
    The 2 channel amps are 2 x 100W into 8 Ohm. Processor is set to small 80hz.
    Do you think it's worth it?
  2. nathan_silly
    nathan_silly
  3. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,133
    Cumbria
    +1,277
    yes
  4. nathan_silly
    nathan_silly
    Yep Ben- will be using two identical 2 channel poweramps, with the non-matching/lesser quality on the rears.
  5. alwyn
    alwyn
    Dec 10, 2002
    562
    west country
    +13
    I have kef ref4 front 40 hz ref200 centre 60hz sides kef hdm1 100hz rear kef ref 2 60 hz all are b/wired and are powerd by five mark levinson amps.my sub rel q400 is set to 40hz. All these settings are as advised by my amp lexicon mc12.Without doubt the b/amping more than pays off
  6. pwiles1968
    pwiles1968
    May 15, 2003
    773
    Leicestershire - England
    +10
    Yes, It is the best money I ever spent. If you already have matching amps hook it up and give it a try.
  7. GaryG
    GaryG
    Nov 20, 2002
    744
    Shropshire
    Depends on how 'lesser' a quality the amp for the rear channels is going to be. If you pull your Audiolab off the rears to power the fronts there will be a slight improvement in performance but you have to weigh this small gain in comparison to the loss at the rear. Are you still running a separate music and AV system?
  8. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,133
    Cumbria
    +1,277
    Right something to think about:
    Bi-amping can lower IM distortion in the critical mid range frequencies and to which the ear is most sensitive. You also get about 4dB more headroom, which can subjectively increase the perceived dynamic range.
    Doubling the power from a new higher power amp will give an additional 3dB of headroom
    So why do people recommend lager power amps over bi amping? You would need to more than double the output to get a similar effect?
  9. nathan_silly
    nathan_silly
    Yup Gary, two seperate audio systems.
    Since rear channel is less important IMO, I'll get something like a Arcam Alpha 8P/9P. I'm pretty sure I don't need a 100W poweramp for rears.
  10. General Skanky
    General Skanky
    Jul 28, 2000
    4,206
    71
    +44
    I biamp my Ref 2s and recommend it. Benefits as Beekeeper states.
